farmall h timing problem
Gary lefkiades
08-19-2004 20:40:00
I am trying to reset the timing on my farmall h.
The shop manual instructs to line up the 2 hash marks on the radiator belt pulley with the pointer
on the engine block and then set the rotor to hit on the #1 point in the distributor.
problem is when the engine was previously overhuled by someone else the crank was removed and replaced without concern of those 2 hash marks.
HOW can I rotate the engine to the #1 firing position without using the hash marks for reference? Can you find the #1 firing position by removing the #1 spark plug and lining it up that way?
Nebraska Cowman
08-20-2004 04:21:00
 Re: farmall h timing problem in reply to Gary lefkiades, 08-19-2004 20:40:00
I don't think you can mess up the marks because the pulley is kyed on. Find top dead center by rotating the engine by hand untill you feel compression on #1 cylinder. contiue cranking until the piston is at the top, (feel in hole with wire or somthing) Then look for your marks and I bet they line up.
farmallsc
08-19-2004 20:42:33
you can remove the distributor and hold your finger over teh hole into the cylinder adn rotate it unitl the cylinder is at its peak position adn pur your distributor back on adn set it
