Virticle distributer on Ebay for Farmall H,M
Mark in Mi
08-20-2004 05:16:25
On Ebay item #3833674618 there is a virticle 4 cylinder distributer with 6 volt coil that states rare. How rare are these and what is the reason for a virticle distributer?
Thanks,
Mark
Bob M
08-20-2004 07:19:56
 Re: Vertical distributer on Ebay for Farmall H,M in reply to Mark in Mi, 08-20-2004 05:16:25
The Delco vertical distributor is also used on stage II (live hydraulic) Super M’s fitted with the Behlen aftermarket power steering kit. The vertical distributor is required as the addition of the Behlen PS pump would push the IHC horizontal distributor back into the oil filter canister.
Also as rustyfarmall and Kelly observe the Delco vertical units are by no means “rare” – I have yet to visit an old tractor show and not see at least 2 or 3 vertical distributors fitted on H’s and M’s.
rustyfarmall
08-20-2004 05:48:55
 Re: Virticle distributer on Ebay for Farmall H,M in reply to Mark in Mi, 08-20-2004 05:16:25
This would be the Delco distributor. It was used when converting from the original magneto ignition. The Delco units are not rare, they are as common as the IH units. I own 6 old Farmalls, 3 of these have the Delco units. The Delco was also used as standard equipment on Case and Allis-Chalmers tractors.
Kelly C
08-20-2004 06:37:40
 Re: Virticle distributer on Ebay for Farmall H,M in reply to rustyfarmall, 08-20-2004 05:48:55
I think some of those guys on Ebay use a pretty loose deffenition of the word RARE.
He could mean. Its rare for me to be selling a dist that actually work. :-)
MagMan
08-20-2004 07:49:27
 Re: Virticle distributer on Ebay for Farmall H,M in reply to Kelly C, 08-20-2004 06:37:40
I agree there has been a LH Trip H4 Magneto on there off and on for starting bid of $225.00 Says VERY RARE I have a pile of these and can hardly give them away. JON
Allan in NE
08-20-2004 06:51:34
Hey Kelly,
How are you coming on the problem tractor? Get 'er figured out yet?
Allan
Allan in NE
08-20-2004 06:49:23
Hey Kelly,
Allan
