smta breather tube
pauls
08-21-2004 15:48:44
Will the breather tube on this tractor drip oil under load. Recently had this tractor under a hard load plowing with 5/16 normaly this tractor is used for bailing and rakeing light use, how ever I have noticed a slight drip from the tube any input will help.Paul
Glenn F
08-22-2004 08:34:44
 Re: smta breather tube in reply to pauls, 08-21-2004 15:48:44
I can't imagine ANY soil conditions where a SMTA could pull 5-16's properly. Lots of M's around here. Glenn
Hermit
08-21-2004 20:33:28
You might want to check if the line from the upper rear of the head to the air cleaner inlet tube is clogged. If it's clogged, the blowby fumes won't be drawn into the intake and be forced out the breather tube.
DWV
08-21-2004 19:02:31
If you mean the breather tube on right side of engine that exits between frame rail and oil pan,
it will do that on a lot of these old tractors.
5/16 plow is to mutch for a SMTA in my area.
CNKS
08-21-2004 18:57:55
It is a sign of blowby, not necessarily serious until it gets worse.
MagMan
08-21-2004 17:11:53
Are you talking about the tube that hooks to the carb Or the one that goes in the back of the head ? I have had Hs and Ms and now a SM all my life and never got oil in the tube that goes to the carb from the breather. And let me tell you I have worked the daylights out of them. The breather tube that goes to the head now that could be normal if you worked her alot and It sounds like you did If its has a leak in it . If you have to much oil going through that tube to the breather maybe that could give you extra oil in the tube that goes to the carb. But if Thats the case I would think you have a motor that has a lot of sludge or something causing alot of blow back. JON
CNKS
08-21-2004 19:01:16
 Re: smta breather tube in reply to MagMan, 08-21-2004 17:11:53
I think he means the one that attaches to the push rod chmaber plate.
CNKS
08-21-2004 19:02:35
 Re: smta breather tube in reply to CNKS, 08-21-2004 19:01:16
That's chAMber.
