To Pauls With the SM
MagMan
08-22-2004 05:11:28
I was wondering what kind of ground you have to pull 5 /16s? I have sandy Loam with no Rocks at all and I dont think I would want Much more than 4/12s or 4/14s if they even made a 4/12 Are you able to go fast enough to turn a good furrow? I have a set of IH 3 bottoms and a ton of different two bottom plows to tell you the truth I pull the Miniapolis Two bottoms with the SM in 3rd at just over an idle. Does a good Job and saves on gas. Over the H in 1st or 2nd at full throttle. JON
pauls
08-22-2004 10:06:07
 Re: To Pauls With the SM in reply to MagMan, 08-22-2004 05:11:28
It was just a bet that the tractor would not be able to pull the 5/16 but it sure did it only plowed about 5 acers and won the bet.pauls.
