smta possible rear main oil leak
pauls
08-22-2004 10:17:34
Recently split this tractor to replace the ta and main clutch,pressure plate bearings ect.When the flywheel was removed for machining I took a real close look at the rear main no oil leaks at all.After reassembly I have noticed a slight oil drip at first I thought it was comming fro the rear main seal but after looking real close it appears to be comming from a plate that is bolted to the back of the of the engine just after the oil pan with 3 bolts it also looks like there is a seal or gasket behind it any help? thanks Pauls.
DWV
08-22-2004 19:09:06
 Re: smta possible rear main oil leak in reply to pauls, 08-22-2004 10:17:34
That plate and gasket just for keeping dust etc. out of flywheel compartment.
