farmall m capacities
nositri
08-22-2004 13:47:00
I haven't gotten around to buying a manual yet for my m. I'm about ready to change the fluids. I would like to know what capacities and what kind it takes of:
Oil
Coolant
hydraulic
transmission
and even how much the fuel tank holds
thanks
Haas
08-22-2004 18:12:32
 Re: farmall m capacities in reply to nositri, 08-22-2004 13:47:00
Red gave the quantities
For coolant, any good quality antifreeze
Engine oil HD 30 wt
hydaulics, non detergent 30 wt oil
transmission 90 wt gear oil, or you can use IH Hytran or equivalent. Some folks don't like the HyTran in the older tractors, but I've got it in my MD and have had no problems. It is a lot lower viscosity than the gear oil but if your seals are good, that won't cause a problem.
The Red
08-22-2004 15:26:16
Oil=8 quarts. Add roughly 1 quart for the air bath cleaner cup.
Coolant=6 gallons
liftall hydraulics=6 quarts for the liftall by itself.
Transmission=13 GALLONS
Fuel tank=21 gallons. If you have the duel fuel settup, the small tank holds roughly a gallon.
