Correct H drawbar height???
John in Ct.
08-23-2004 05:44:51
I want to set the drawbar on my Farmall H to a correct height. I know that it is adjustable (Up and down) for different equipment. Is there an "ideal specification" measurement from the drawbar top to say the PTO shaft or drawbar top to the ground? Thanks!!
rustyfarmall
08-23-2004 07:19:14
 Re: Correct H drawbar height??? in reply to John in Ct., 08-23-2004 05:44:51
The correct height is determined by the implement you are using. For general use I like to set mine so that it appears level with the rest of the tractor.
Allan in NE
08-23-2004 18:47:02
 Re: Correct H drawbar height??? in reply to rustyfarmall, 08-23-2004 07:19:14
I can't imagine anyone running it other than level. Seems like it would put a bind on everything.
You ever heard of this in all your travels?
Allan
rustyfarmall
08-23-2004 19:12:34
 Re: Correct H drawbar height??? in reply to Allan in NE, 08-23-2004 18:47:02
I bought an H a few years ago that had the drawbar adjusted to its highest position, I haven"t the foggiest notion why. The previous owner knew very little about what a tractor should be used for. He had even managed somehow to bend the swinging drawbar into a semi-horseshoe shape. I bought the tractor cheap, and only because somehow or other it had the c-164 engine.
