A pitman arm
Rusty McCulley
08-23-2004 09:20:54
I am looking for a pitman arm to repair the steering on a Farmall A. I think it is a 1948 or so, with a tapered and keyed shaft. Anybody got any ideas?
Rusty
Rusty McCulley
08-24-2004 06:35:16
 Re: A pitman arm in reply to Rusty McCulley, 08-23-2004 09:20:54
Thanks guys. Jon, the arm I have now came from ebay, but it turned out to be the wrong shaft configuration. It has square hole instead of the tapered round that I need. Might be a home-brew from the looks of it.
Jim Becker
08-24-2004 17:48:13
 Re: A pitman arm in reply to Rusty McCulley, 08-24-2004 06:35:16
Square hole was the earlier design. Both the shaft and arm changed (ovbiously). If your tractor is a '48. it probably started out with the square hole.
Rusty McCulley
08-25-2004 06:38:02
 Re: A pitman arm in reply to Jim Becker, 08-24-2004 17:48:13
Thanks for the info Jim. My tractor is an "A" with elect. start and that's about all I can be sure of. The guy I got it from is where I got the '48 figure. I guess I've got a good pitman arm for a square steering shaft Farmall if ennybody needs one:) Thanks again.
MagMan
08-23-2004 09:44:48
Did you check Ebay? JON
