6 Volt Battery Question
waynekittler
08-23-2004 20:50:45
Cannot get the H starter to turn over after engaging. Changed the switch-no difference. Battery took charge okay by meter. Is it possible for a 6 volt battery to lose amp power and still show good charge ?
Michael Soldan
08-24-2004 18:06:16
 Re: 6 Volt Battery Question in reply to waynekittler, 08-23-2004 20:50:45
Wayne, you could have a fully charged battery with one dead cell, giving you a wopping powerfull 4 volts that won't do anything to the tractor, sounds like a battery problem to me...Mike in Exeter Ontario
Sam#3
08-24-2004 05:18:35
In a word, Yes.
As a battery ages the internal chemistry changes and, in effect, it consumes more of it's own power than it distributes. Put it on a load tester.
Wayne Swenson
08-23-2004 21:07:37
The starter drive is likely stuck in mesh with the flywheel. Either rotate the crankshaft back by turning the fan or put in 5th gear & rock the tractor back & forth to disengage the starter drive.
John *.?-!.* cub owner
08-24-2004 06:35:52
 Re: 6 Volt Battery Question in reply to Wayne Swenson, 08-23-2004 21:07:37
And if you can't loosen it that way, loosen the starter mounting bolts and try again.
