Need to know, torqueclearance for 1937 F-30...
Sharecropper
08-23-2004 21:01:04
Farmall rod bearings.
El Toro
08-26-2004 04:14:54
 Re: Need to know, torqueclearance for 1937 F-30... in reply to Sharecropper, 08-23-2004 21:01:04
Hi, I think that rod clearance should be near .0015". The torque on the rod bolts 45-50 ft-lbs. I saw an F30 for sale in the Lancaster Farming PA newspaper for $5000.00. Hal
Sharecropper
08-23-2004 21:02:56
 should say torque and clearance in reply to Sharecropper, 08-23-2004 21:01:04
for F-30 Farmall rod bearings.
JerePa
08-24-2004 17:38:11
 Re: should say torque and clearance in reply to Sharecropper, 08-23-2004 21:02:56
There is no spec given by IH that I know of. Using the diameter of the bolt & thread type, look up on a standard bolt torque chart. Remember, they are old bolts so don't exceed the spec or you will have a failure.
