Int. 384 parts
Rob J
08-24-2004 13:03:34
Does anyone have a good source for an Int. 384? Mainly looking at transmission parts. I need a 1st, reverse and a spline gear (if I recall the name correctly). The spline gear is part of the hi/lo range I believe. New or used parts.
Thanks,
Rob
mowr
08-24-2004 20:12:29
 Re: Int. 384 parts in reply to Rob J, 08-24-2004 13:03:34
Have you checked with a Case-IH/Mahindra dealer? I've seen posts on this site stating that some Mahindra parts interchange with these.
Rob j
08-25-2004 07:34:39
 Not yet... in reply to mowr, 08-24-2004 20:12:29
The IH dealer is who we're trying to avoid. They want $800 for the spline gear and a couple hundred each for the 1st and reverse gears. WAY out of our range for an old tractor.
thanks,
Rob
JB
08-24-2004 19:24:38
Hi, the 384 was the newest version of the UK built B275, B276, B414, 434, 444 and there also was an industrial model all with the same transmission but some industrial models had a "fast reverse" transmission option.
If you can't find parts in the US try searching the web for Canadian trator wreckers as these models were very plentiful in Canada.
Here is link to CND salvage yard:
Link
Good luck
JB
