SideDresser 100
JD Carter
08-24-2004 17:25:47
Should the side dresser for A 130 Fit my 100 ;it is going to but, I have had to customize two of the brackets so far. My 100 had the final drive sprocket on the left side (seated on the tractor) and I am having to move it to the right side to make this thing work. I am none the less overjoyed to have this attachment as it has been a challenge to find one in decent condition..
JD
eugehe
08-29-2004 15:12:38
 Re: SideDresser 100 in reply to JD Carter, 08-24-2004 17:25:47
J D that 100 should have a cap on the left side that you take off and bolt the drive sprocket on. if not it is the first one i have heard that did not.you will sure have a job getting it to work from the right side if it is like my 140
