Farmall Distributor
Brian Schmidt
08-25-2004 05:30:25
I am working on a 450 Farmall. It has much slop in the distributor shaft where the points ride and the rotor fit on. You can open and close the points by moving the shaft. Are these rebuildable or do I need to find a different distributor?
Jer
08-25-2004 06:42:25
 Re: Farmall Distributor in reply to Brian Schmidt, 08-25-2004 05:30:25
I have a nice distributor for a 450 if you are interested
rustyfarmall
08-25-2004 06:37:34
There are a couple of bronze bushings in there that can be replaced. Hopefully the shaft is not worn too much, but that can be replaced/repaired also.
Brian Schmidt
08-25-2004 06:48:43
 Re: Farmall Distributor in reply to rustyfarmall, 08-25-2004 06:37:34
Are these parts available from the dealer or do I have to go to a distributor shop/machine shop?
rustyfarmall
08-25-2004 07:40:22
 Re: Farmall Distributor in reply to Brian Schmidt, 08-25-2004 06:48:43
I can"t say for sure but I would check with the dealer first.
