Sticking valves
Don
08-25-2004 05:52:34
What is the best way to free sticking valves? Thanks in advance,Don.
ChadS
08-25-2004 13:52:23
 Re: Sticking valves in reply to Don, 08-25-2004 05:52:34
Put some transmission fluid in a squirt bottle, mix a bit of mineral spirits with it,, run the tractor at full throttle, and inject the mixture into the carb inlet, dont over do it, it will lube up the entire top end, and clean it out pretty good, the manifold will get extremly hot during this, but works every time. CHadS
Red Dave
08-25-2004 06:23:06
If the tractor is running, I have found Marvel Mystery Oil to be effective. Some in the oil, some in the gas.
Worked for me anyhow.
