Float adjustment help
kraigWY
08-25-2004 10:51:14
I am working on my neighbors Industrial IH, I am not sure of the model but it looks like a 3oo-330. I have no informantion on this tractor and I am hoping some one could tell me the float adjustment on the carb. I got it to flood out and now allow any fuel at all, I know there is a messurement I am suppose to be using but what is it?
Thanks
Loren
08-25-2004 18:36:11
 Don't know if you've gotten any help yet. in reply to kraigWY, 08-25-2004 10:51:14
I only have an IT-10 manual, covers 300,300U, 350,350U and other higher numbers. Don't know about your's fitting in here. It says "Distance from the farthest face of the float to gasket surfaceof throttle body when inlet needle is closed is 1&15/16ths inch. This float setting provides a fuel level of 9/16ths-21/32nds inch. If I don't have a spec I've had real good luck setting the float parallel to the carb body. Should work pretty good till you get the right setting. Loren
