solvent for cured RTV
riverbend
08-25-2004 11:04:01
Is there a solvent that will dissolve cured silicone sealer (blue Permatex)?
Thansk
Greg
John *.?-!.* cub owner
08-25-2004 20:25:25
 Re: solvent for cured RTV in reply to riverbend, 08-25-2004 11:04:01
If you are trying to get it off mating surfaces to reinstal them try a wire brush in an electric drill.
Jim's sls
08-25-2004 18:08:27
mineral spirits works great after you"ve gotten the big stuff off with a razor blade. it"s cheap and doesn"t usually attack much paint! just keep wipin it on and the rtv curls up and flakes off!
catmandoo
08-25-2004 18:31:37
 Re: solvent for cured RTV in reply to Jim's sls, 08-25-2004 18:08:27
i usually get the major stuff off with a putty knife and razor then take a scotchbrite pad to it.
mpj
08-25-2004 17:39:42
gasoline.
Pete L
08-25-2004 17:18:31
Rubbing alcohol is a good surface cleaner, and a solvent while it is still liquid and hasn't started to set. After that, a razor blade it your best choice. Note too that silicone doesn't stick well to cured silicone.
MagMan
08-25-2004 13:20:58
OK I might as well use my two cents. I buy carb cleaner at walmart for .88 cents a can and boxs of single edge razor blades from the cheap tool sales works for me. JON
rustyfarmall
08-25-2004 14:22:38
 Re: solvent for cured RTV in reply to MagMan, 08-25-2004 13:20:58
Don"t mean to argue with you but the carb cleaner will remove paint also.
John M
08-25-2004 12:42:10
Putty Knife!
Robert (ID)
08-25-2004 11:29:19
i dont know of 1 that will disolve it but starting fluid is what i have used to get it to break its hold on parts!!
rustyfarmall
08-25-2004 11:09:10
I think plain old rubbing alcohol will probably work.
superih
08-26-2004 06:39:12
 Re: solvent for cured RTV in reply to rustyfarmall, 08-25-2004 11:09:10
After silicon is allowed to cross-link (setup) it cannot be dissolved. In fact it takes somewhere around 3000 deg F to burn the stuff.
