BN clutch project - - wisdom sought
Pete L
08-25-2004 17:23:54
Guys - - Have an opportunity to buy a BN with a bad clutch. Big project? Probably have to split the tractor to do this. Any words of wisdom on the task? What else should be done once I'm in that far? Thanx !
Kurow
08-26-2004 20:53:53
 Re: BN clutch project - - wisdom sought in reply to Pete L, 08-25-2004 17:23:54
There are 2 frost plugs--replace both. If it is a BN buy it. Not that common and a neat tractor. Also easier to shift on a trailer than the wider B.
Regards from NZ
mbnok
08-25-2004 20:17:58
There is a soft plug behind the flywheel, inspect it, any doubt, replace it.
Red Dave
08-25-2004 18:09:18
Not a hard job. I split my B by blocking up the rear end and picking the front off with an engine hoist.
While you"re in there replace all of it, disk, pressure plate, throw out bearing and pilot bearing too.
