hydraulic level on farmall 340
steve-ny
08-25-2004 18:23:19
old timer friend of mine is working on this 340, and needs to know where (and how much)to add the hydraulic system. thanks steve-ny
PUTTER
08-26-2004 06:08:40
 Re: hydraulic level on farmall 340 in reply to steve-ny, 08-25-2004 18:23:19
Steve
There is a plug on the left side of the tractor. You will find it behind the clutch peddle. The plug will have a small bolt in it. Remove the small bolt then add fluid in large plug on top of trans case next to shift lever. If he's having hyd problems I would change the fluid and the filter. PUTTER
Al L. in Wisc.
08-25-2004 19:13:50
You will see a plug with a square 'hole' in it, near the shift lever. I used the socket wrench itself to turn the plug out. Clean away any foreign material around the plug first. When I drained mine, I also replaced the filter and the system takes 10 gallons - 340 non diesel engine, per I&T IH Shop Manual. Hope this helps and good luck. I like my Farmall 340 row-crop, great tractor!
catmandoo
08-26-2004 05:30:35
 Re: hydraulic level on farmall 340 in reply to Al L. in Wisc., 08-25-2004 19:13:50
on my 460 there is a little plug on the left side just under the running board this is the full level,pull the plug and when the fluid runs out she"s full.
