Super H dies under load
Jeff Wenner
08-26-2004 10:51:25
My freind"s Super H boggs down and almost dies under a load. Carb was rebuilt last year, should be in good shape. Any ideas? What should the jets be set at to start? Thanks.
CNKS
08-26-2004 18:30:17
 Re: Super H dies under load in reply to Jeff Wenner, 08-26-2004 10:51:25
Set the main jet 5 turns out. It is NOT adjusted like the regular H. You can turn it in for better fuel economy, but turned in too far it will do as you describe.
Nebraska Cowman
08-26-2004 16:47:38
points will do that.
TP from Central PA
08-26-2004 17:58:00
 Re: Super H dies under load in reply to Nebraska Cowman, 08-26-2004 16:47:38
Yeah, agree with that..... .....All the parts on the ignition system should be in good shape as well.
The Red
08-26-2004 15:23:52
Crack open the high speed mixture screw a half turn and see if that helps. It might be running too lean.
Pat H
08-26-2004 13:47:47
Got rust in the tank? Maybe something partially plugging sediment bowl. Maybe the rubber hose from carb to air cleaner is seperated and partly choking it off. Hope this helps. Pat in Wisc
rustyfarmall
08-26-2004 11:12:23
What kind of load?
Mark Ruby
08-28-2004 12:46:05
 Re: Super H dies under load in reply to rustyfarmall, 08-26-2004 11:12:23
check and make shure the govoner is working
