painting 1206
Joe
08-26-2004 17:39:31
Im gonna paint the old 1206 and was wondering what you guys thought is the best paint to use? Also if anyone knows where I can buy the 1206 metal side emblems? All I can get from my CIH dealer is stickers. Thanks in advance.
CNKS
08-26-2004 17:55:41
 Re: painting 1206 in reply to Joe, 08-26-2004 17:39:31
Case-IH 2150 red at a minimum, a step up is PPG, DuPont, etc acrylic enamel, a step up from that is acrylic urethane. I don't know the white code -- I need to find that out also. If you use hardener, you need a supplied air system because a charcoal filter mask will not filter out the isocyanates in the hardener. Be sure to use an epoxy primer as the first coat.
Sharky
08-26-2004 18:26:24
 Re: painting 1206 in reply to CNKS, 08-26-2004 17:55:41
If the white on the 1206 is the same as the white on the early Cub Lo Boys (i.e. 1959 model) I've used PPG MAE 8365 A, It has a slightly "Greenish" cast to it which makes the creamy white color on the two tone Farmall's. Not sure what year the 1206 is but if it's close I bet 8365 A is your color....
CNKS
08-26-2004 18:49:35
 Re: painting 1206 in reply to Sharky, 08-26-2004 18:26:24
Provided it crosses to the original IH number -- that's the one I don't remember -- shouldn't be hard to find, I'm not ready to paint yet.
