560 diesel injection pump
Lance Ropte
08-26-2004 19:57:21
I have two 560 diesels. 1960 has a Roosa Master model# 1683293 and the 1961 has a Roosa Master model #240340. They look identical to me. I was told that the injection pump on the 1961 is not original but an improved pump which responds better. Does anyone know anything about this?
Chris Brown
08-27-2004 04:59:30
 Re: 560 diesel injection pump in reply to Lance Ropte, 08-26-2004 19:57:21
I don"t have the part #"s ,but yes there was a newer pump with better starting and better governor response. I have one of the newer ones out in the field I plan to put on my tractor someday. There is a noticible difference,not in actual power,but it sounds tighter and quicker.Also the governor holds rpm"s closer to set rpms.
Lance Ropte
08-27-2004 07:32:22
 Re: 560 diesel injection pump in reply to Chris Brown, 08-27-2004 04:59:30
Maybe thats why my newer 560 always starts so much more quickly than the older one. You are right about the noticably better performance.
Chris Brown
08-27-2004 17:44:41
 Re: 560 diesel injection pump in reply to Lance Ropte, 08-27-2004 07:32:22
I want to change pumps on mine, But I hate to fix it if it ain"t broke.
