wiring diagram for International 404
Ellen
08-27-2004 06:38:09
I recently screwed up my great running tractor by removing the dash and encountered a plethora of rusted, rotting, dangling wires!! Now it won"t start; I invariably broke or shorted a wire somewhere. Of course, most of the guages had previously been discontected.
She wants to run and will start, somewhat, as long as the switch is engaged and the starter is cranking. As soon as you let off the switch it dies.
Can someone assist me with a wiring diagram? This is a 1967, 404.
Thank you, Ellen
J in Pa
08-27-2004 15:43:29
 Re: wiring diagram for International 404 in reply to Ellen, 08-27-2004 06:38:09
ellen send me your e-mail addy and i will send you the wiring diagrams for your 404.
heres mine..... .
dejo@zoominternet.net
J in Pa
captink
08-27-2004 07:14:43
It sounds to me like the wire from the ignition switch to the resistor is not powered when the switch is on. It was designed to so that it starts on 12V and runs on 6V. Someone else will post to help you find a wiring diagram.
