INJECTION PUMP ON 606
johann
08-27-2004 09:38:09
HELP! The flange on the injection pump broke in half while it was being installed. I think this happened because the injection lines were put on and tightened down and then the pump was drawn up tight to the motor. For whatever reason, the pump is still broke. Will this work? Make a collar and and drill and tread a series of holes through the broken and good part of the pump, and mount it this way. Or am I looking at raplacing the entire pump? Any other fixes and advice are welcome.
Aces
08-27-2004 13:09:35
 Re: INJECTION PUMP ON 606 in reply to johann, 08-27-2004 09:38:09
Johann very little misalinment of the pump and it will take the pump drive shaft out, I would not, this way you have pump parts to put in different housing, if the fhaft goes you WILL have less good parts.
