farmall H trans.
Jpaustin
08-27-2004 09:56:18
My H when in 5th gear pops out of gear all the time. I replaced the front fork and it still continues to pop out any help thanks
captaink
08-27-2004 10:04:14
 Re: farmall H trans. in reply to Jpaustin, 08-27-2004 09:56:18
Did you replace the spring and ball that hold the shift fork in position? If not, that is a place to start. While you have the cover off, check how rounded the teeth are on the gears. If they are rounded too much, the pressures between them will always try to walk them apart, popping them out of gear. LOL.
