? for super c gurus
wh
08-28-2004 12:02:46
anybody know the seal # for the seal that goes in the steering sector where the top shaft connects to the steering shaft/ mine was leaking (pouring) and tore it up getting it out.
MN Scott
08-28-2004 20:41:08
 Re: ? for super c gurus in reply to wh, 08-28-2004 12:02:46
I'am not sure what seal you are refering to so I will give you all seal numbers for the front steering gear box. The seal for the steering input worm shaft is, 43800DA. seal for output bolster shaft, 360457R91. The internal seal for the output bolster shaft,352417R1. The two gaskets for the bottom are, upper, 52951D. Lower, 52952D. You can go to the CR or National website and cross these to their current numbers. Hope this helps you.
wh
08-29-2004 06:25:02
 Thanks !! in reply to MN Scott, 08-28-2004 20:41:08
the 43800 is the one i need.
TDK
08-29-2004 13:26:04
 Re: Thanks !! in reply to wh, 08-29-2004 06:25:02
The C/R # for that seal is #9876. Just replaced them in my S/C recently.
