Front Hubs On M
RHW
08-29-2004 13:30:37
Is there any other farmall hubs that will interchange with a m hub so I can change the front wheels to pressed steele to lighten the front ?
Novel Idea Guy
08-30-2004 15:16:42
 Re: Front Hubs On M in reply to RHW, 08-29-2004 13:30:37
Someone should tell that guy below to read the post. Why would you switch from M to H hubs to lose weight when they"re the exact same hub? Sheesh.
Anyway, for the whopping two pounds you"d save, and that"s being optomistic, it ain"t worth it. If you really wanted to, I believe the spindles are pretty much the same right up through. You could put a "standard" 6-bolt implement hub right on there with the original wheel bearings.
The Red
08-29-2004 15:00:30
Interchange with the H.
Paul A.
08-30-2004 09:30:50
 Re: Front Hubs On M in reply to The Red, 08-29-2004 15:00:30
'M' front hubs will fit on an 'H'???
Novel Idea Guy
08-30-2004 15:21:01
 Re: Front Hubs On M in reply to Paul A., 08-30-2004 09:30:50
Yes. They"re the exact same hub.
