Super C power increase ideas?
Steve in FL
08-29-2004 15:24:08
I am about ready to undertake a complete engine rebuild on my 1954 Super C and am looking for any other ideas to boost the power. As with alot of us I can't seem to do a rebuild without trying to add a little more power. My plans are to increase the power as much as possible and keep it looking stock. I plan to bring it up to 230 specs by using 200 to 230 pistons to up the compression ratio from 6.0 to 6.5 and to use a governor out of a 230 to get the rpm's to 1800. I want to use a 6 volt electronic ignition and high voltage coil conversion. Any other ideas? Any unforeseen problems with my plans so far? Any aftermarket suppliers for 123 engines? Thanks!
justin w
08-29-2004 16:39:54
 Re: Super C power increase ideas? in reply to Steve in FL, 08-29-2004 15:24:08
The Super C can do more in the way of producing HP if you use the later cylinder head (366299R1). The 230 will only max out at a bore diameter of 3-1/8", but the Super C can carry a bore diameter as large as 3-1/4".. Of course you will also want to use the governor spring from a 230 or another engine with a higer rated speed.
