Super MTA p.s. pump help needed!!!
MarkinIN
08-29-2004 18:51:13
A friend of mine just bought a very nice Super MTA with add on power steering. It looks like it is an old Saginaw pump with the reservoir on top of it. The front seal had a melt down last week and lost all of its fluid. The pulley is also bent up. Can anyone tell me what older vehicle may have used this type of pump so that I can start to track one down? It looks like it"s from a 60"s vintage G.M. Thanks Mark
BIG JOHN
08-30-2004 18:35:27
 Re: Super MTA p.s. pump help needed!!! in reply to MarkinIN, 08-29-2004 18:51:13
You DO NOT need a pump. You can use the live power on your SMTA to power the power steering and do away with the aux pump. You will need a power divider valve in the system and you will be good to go.
My SMTA had the same set up as yours and also the same problem. I took the pump, pully, reservior and hoses off and replumbed the hydraulic lines from the live power and put a power divider valve in the system and it works perfect. You will do away with repair and maintance or replacement of the old pump.
NDS
08-30-2004 06:39:34
I have 1987 model Chev. truck that has this type pump. You can still buy rebuilt pumps at NAPA etc.
