Brake question on IH 274
Jerry Ward
08-30-2004 10:17:09
I got a 274 (Offset diesel row crop) running last night for the first time in almost a year. Nothing really wrong, some kind of fuel restriction in the valve coming out of the tank. So I drained out all the old diesel, cleaned out the valve, changed the filter and after several almost starts in was running good. However I stepped on the brakes and the left side stayed engaged. The brakes are hydraulic and the pedal now goes down with no resistance. Is there some kind of parking brake that is set or do I have something stuck in the brake circuit?
Lloyd
11-20-2004 21:22:02
 Re: Brake question on IH 274 in reply to Jerry Ward, 08-30-2004 10:17:09
Jerry, It is a little late posting, May help some one else.
The parking brake is on the left side of the seat on the foot rest. I suspect what your trouble is, is water and junk in the master brake cylinder. They both needs removed and cleaned and flushed and new fluid installed. IH recommends the same fluid as in the transmission. I am in the process of doing the very same thing, except I am going back with DOT 5, silicone fluid and see if I can cover the reservoir so it will stay clean.
IH says to replace the complete master cylinder. I don't know if it is still available
