Side flywheel bearing replacment
Bob Quale
08-30-2004 12:09:20
I need to replace the bearings on the side fly wheel on my w-4. I can't get the one closest to the fly wheel off. I am afraid to put a puller on the cast flange to pull it, any ideas?
Thanks again for the help!!
Bob
lee
08-31-2004 08:57:10
 Re: Side flywheel bearing replacment in reply to Bob Quale, 08-30-2004 12:09:20
It's not going to jump off there on its own.
Bob Quale
08-31-2004 06:10:49
Wayne,
Yes it is the side fly wheel. There is a snap ring and I did remove it. It looks like the snap ring holds the bearing in the casting. (I have a parts manual break down).I just can't budge the thing. The casting is a thin flange that bolts to the housing on the transmission. If I put a puller on it it will break for sure.
Wayne Swenson
08-30-2004 21:17:29
Are you referring to the belt pulley drive? Check for a snap ring holding the bearing in place.
lee
08-30-2004 14:57:52
I'm not familiar with the configuraton but I'd put a puller of some type, a slap hammer type might be more effective, and add a little heat in appropriate places.
