Made lots of kindeling but I got em
MagMan
08-30-2004 16:01:46
Well I finally got those pistons out of that block. I split enough wood today to make several fires. Two of the pistons came out with the sleeves I have to figure out how to get them out now. After getting a piston out and cleaned up I find that they are not M&W. It says W M W And A-1019 I am not sure if M&W made flat tops or not but they look to be a pretty good set for power they are long and heavy like the origenal metal ones. I have had several motors apart in my life but I have never seen pistons that fit in the sleeves so dang tight. JON
justin w
08-30-2004 16:47:13
 Re: Made lots of kindeling but I got em in reply to MagMan, 08-30-2004 16:01:46
A-1019 is a clevite number. The piston is a flat top aluminum piston in 3-7/16" bore that uses two 3/32 compression rings, one 1/8" Compression ring, and one 1/4" oil ring.. The compression height on the piston is 2-1/2"
MagMan
08-30-2004 18:39:35
 Re: Made lots of kindeling but I got em in reply to justin w, 08-30-2004 16:47:13
Boy It sounds like you nailed that one right on the head. What is the compression height? JON
justin w
08-30-2004 19:13:55
 Re: Made lots of kindeling but I got em in reply to MagMan, 08-30-2004 18:39:35
2-1/2"
justin w
08-30-2004 19:13:48
2-1/2"
MagMan
08-30-2004 19:22:55
 Re: Made lots of kindeling but I got em in reply to justin w, 08-30-2004 19:13:48
Yes I get that but what is the meaning of the 2 1/2" JON
justin w
08-30-2004 19:36:17
 Re: Made lots of kindeling but I got em in reply to MagMan, 08-30-2004 19:22:55
That is the distance from the center of the wrist pin to the top of the piston.
