Help with oil drip
Farmer Bob
08-30-2004 19:34:19
After complete out of frame overhaul on a D-166 out of a Farmall 340D, I"m getting a steady drip out of the crankcase breather pipe on the left side of the engine after the engine warms up. Running Delo 400 straight 30W oil and new gauge showing about 45-50 lbs oil pressure. Everything in this engine was replaced new or to spec. New packing was installed in the "Box" that the tube fastens to as well.
captaink
08-31-2004 06:19:59
 Re: Help with oil drip in reply to Farmer Bob, 08-30-2004 19:34:19
While the engine is running, check to see how much blow-by is coming out of the breather pipe. If it is a lot more than barely noticeable, you have compression pressure in the crankcase. This most likely is coming from poorly seating compression rings in the engine.
I’m not familiar with that particular engine, but the H, M, 300, 350, 400, 450, etc all have tube that runs from a tap in the head back to the air cleaner. This is to get the blow-by out of the crankcase and run it back through the engine. There may be a plug in this line or passage in the head somewhere.
Hope this helps!
