one touch
badzygote
08-30-2004 20:19:46
i have a 62 farmall 140 w/ the touch control system and my hydraulics stopped working. i mowed w/ it, pulled it up into the yard, shut it off, went inside, came back out started the tractor and....the mower deck wouldn't raise. i have the owners manual but there's no diagram of the touch control system. please help.
thank you,
badzygote
Hugh MacKay
08-31-2004 02:17:32
 Re: one touch in reply to badzygote, 08-30-2004 20:19:46
When was the last time you checked the fluid level in hydraulics. Those need to be watched closely as they can start leaking along pump shaft and into crankcase and you never see the leak. Hydraulic resovoir on those is quite small.
