Rotocycle cutter
Dale Kite
08-31-2004 14:10:31
I have a Rotocycle Cutter with 2 point that fits the Super C and up. I am in need of the gears as these are worn badly. Would gears from another brand cutter fit and also what is the color supposed to be? Thank for any help.
El Toro
09-01-2004 06:43:55
 Re: Rotocycle cutter in reply to Dale Kite, 08-31-2004 14:10:31
Hi Dale, Try this company called ATCH-MONT Gear Company, Inc. Their email address is atchmont@atchmontgear.com. Their phone number is 215-355-5146. You can probably view them by clicking on "keyword" and type in the company
name. I found it under gear manufacturers. Hal
PS: They specialize in gear boxes.
chalierocknroll
10-09-2004 04:32:19
 Re: Rotocycle cutter in reply to El Toro, 09-01-2004 06:43:55
I have a complete part list for the Rotocycle cutters. It is a copy of the original with all parts listed.
Ron Wood
11-08-2004 13:03:26
 Re: Rotocycle cutter in reply to chalierocknroll, 10-09-2004 04:32:19
I have a 10'rotocycle cutter an need the shaft on the center gear box. Do you have the part number for this item or know where I can get one?
El Toro
09-01-2004 06:06:28
Hi Dale, Look those gears over to see if any
numbers are on them. They may be able to cross reference them to another manufacturer. Good Luck, Hal
michael d. harris
08-31-2004 19:57:26
I own a five foot pulltype rotocycle cutter. The color on my cutter is a dark yellow. It is a few shades darker than John Deere yellow. The manufacturer is no longer manufaturing cutters. You will have to find a machine shop to make or fix your gears. Another option would be to adapt another gear box to your cutter.
