574 Hy-Tran fluid level
wolfy
08-31-2004 18:48:00
When checking fluid level of htdraulic-transmission, should the 3-pt lift arms be raised or in lowered position?
Bernard le mécano
09-01-2004 18:44:15
 Re: 574 Hy-Tran fluid level in reply to wolfy, 08-31-2004 18:48:00
Hi Wolfy, check with the engine running at idle. It have 3 section in the transmission box with not the same level when the engine run.
Bernard le mécano Québec Canada
wolfy
09-01-2004 19:09:04
 Re: 574 Hy-Tran fluid level in reply to Bernard le mécano, 09-01-2004 18:44:15
Thanks, Bernard.
Wayne M Kittler
08-31-2004 19:03:01
Does not matter. Fill to full mark with tractor off.
wolfy
09-01-2004 19:11:13
 Re: 574 Hy-Tran fluid level in reply to Wayne M Kittler, 08-31-2004 19:03:01
Thanks Wayne.
