Magnafluxing Prices
MagMan
09-01-2004 10:03:25
I was wondering if anyone knew what the going rate for magnafluxing on a 4 cyl H block and head would be these days? JON
Red Dread
09-02-2004 03:54:44
 Re: Magnafluxing Prices in reply to MagMan, 09-01-2004 10:03:25
The machine shop I took it to in MO. charged $20 to magnaflux the head on my H and found three cracks, which they fixed.
Gene
09-01-2004 22:34:35
Pull the pan. Fill the block with water (since the head is off) and see if there is water leaking around the bottom of the sleeves. Just a guess. I think one of the O rings around the bottom of a sleeve is bad.
Dr.EVIL
09-02-2004 11:12:17
 Re: Magnafluxing Prices in reply to Gene, 09-01-2004 22:34:35
H's & M's are dry liners. No o-rings. But the block may be cracked or have a hole under the sleeve.
Steven f/AZ
09-01-2004 17:42:45
My local shop back home did it for free usually. Of course I did a lot of business there at the time... To the tune of about $400 per week for 6 weeks!
caseyc
09-01-2004 15:22:27
my local carquest gets $12 to do a head, just had one done. don"t know about a block. can"t imagine a whole lot more. maybe $30?
lee
09-01-2004 13:57:21
You'll do best to call a few automotive shops in your area. Do you suspect or have you had a problem with the block or head?
MagMan
09-01-2004 15:42:51
 Re: Magnafluxing Prices in reply to lee, 09-01-2004 13:57:21
I bought this tractor and it had aprox 2 gal of anti freeze in the base. No sighs of cracks to the naked eye and the head gasket looked ok I dont know if someone did this or there is a crack somewhere. That much antifreeze would make you think you would see a problem. JON
