Explain what a cutoff is
Dave Barkley
09-01-2004 10:36:02
Can anyone explain what a cut off is when talking about rims.
Dave barkley
09-02-2004 12:08:27
 Re: Explain what a cutoff is in reply to Dave Barkley, 09-01-2004 10:36:02
Thanks for all of the information. This may not come out right but why would people now a days choose a cutoff over a factory wheel. Is it because most of the spoke wheels were steel and not rubber.
Keith T
09-02-2004 11:47:54
Just about every small town blacksmith would do these conversions .Some were real artists and some were butchers.This was really big business in the 1940's after WW11 when rubber tires became readily available.
Kelly C
09-01-2004 18:15:07
third party image
This is a cut off
pg
09-01-2004 10:42:00
cut-offs are or were steel wheels. way back when, they got sick of riding on steel wheels with or without lugs. so they cut off the outer steel rim and welded rims onto the spokes that would except rubber tires. there were many thriving business that did this for whoever wanted them. if only they knew,..... pg
Stan(PA)
09-01-2004 13:10:44
 Re: Explain what a cutoff is in reply to pg, 09-01-2004 10:42:00
Are most of the cutoffs "true", that is, are they not slightly out of round?
Jim Becker
09-01-2004 20:17:37
 Re: Explain what a cutoff is in reply to Stan(PA), 09-01-2004 13:10:44
Not bad.
The tire companies had fixtures that you mounted the wheel on. They had a rotating clamp that held the torch so it would swing in a perfect circle. If you knew what you were doing, you could make a pretty true conversion.
