Farmall C pto shaft replacement
wildman
09-01-2004 18:23:09
What is the process of changing pto shaft in my Farmall C are there any hidden suprises behind covers.Thanks in advance.
Haas
09-01-2004 20:10:50
 Re: Farmall C pto shaft replacement in reply to wildman, 09-01-2004 18:23:09
The gear must come off the shaft to get the old shaft out. You need a puller. Don't try to drive the shaft out, as the woodruff key on the gear shaft will not pass through the bearing race. Gear has to come off first and remove key before the shaft can come out.
Jim Becker
09-01-2004 19:56:19
Surprises? just that the gear oil will all run out if you don't drain it before pulling the PTO.
