Super C carb - Carter vs. Zenith
Steve in FL
09-01-2004 18:33:12
First of all, thanks to MM_TX for pointing me in the right direction on the correct carb for the Super C. Apparently a Carter or a Zenith is appropriate which leads to this question: What is the better of the two?
MM_TX
09-01-2004 19:57:17
 Re: Super C carb - Carter vs. Zenith in reply to Steve in FL, 09-01-2004 18:33:12
Steve I read a lot of old posts & I gathered more like Zenith. The new replacements are all Zenith. My 51 SC had a Carter on it (which has an aloy housing). It had water in it and was so carroded that I could not get any of the needles or jets out. I had 2 Zenith carbs (that have metal housings) off 2 parts Bs and both cleaned up like new. I but one on the SC and it runs fine. I am soaking the Carter in hopes I can take it apart. The brass parts seem to fuse to the aloy.
parts man
09-01-2004 19:09:33
Steve, either carb works just fine (I rather like the Carter) but Carter carbs tend to be hard to find parts for.
