WHat the heck do you call it? McCormick? IH? Farma
Frank Richardso
09-02-2004 21:24:07
I"m new to tractors. I am pretty confused by what seems to be an identity crisis anything IH made. I"m looking at a 1956 300. It has the IH hood ornament, a "McCormick" emblem on the side and the "Farmall". So how do you correctly refer to it?
International Harvestor 300
Farmall 300
McCormick 300
International Harvestor Farmall 300
International Harvestor Farmall McCormick 300
McCormick Farmall 300
Farmall McCormick International Harvestor 300
McCormick Farmall International Harvestor 300
etc. I"m sure folks would know what I meant no matter which one of these I use ,but it sure is confusing for us new guys.
sammy the RED
09-03-2004 23:26:32
 Re: WHat the heck do you call it? McCormick? IH? F in reply to Frank Richardson, 09-02-2004 21:24:07
IH - McCormic - Farmall - 300
GM - Chevy - Corvette - Stingray
Georgia Boy
09-03-2004 19:45:51
Whatever you want to call it I think you should but this classic tractor! Looking at one myself.
Harold H
09-03-2004 05:43:10
You should call your 300 a "Farmall 300". It is technically a "McCormick Farmall 300 built by International Harvester". If it was a utility model you would call it a "International 300" which is technically a "McCormick International 300 Utility built by International Harvester". Generall speeking, from the 20's to the 50's, Row crop IHC tractors were "Farmall", standard wheel tractors were "McCormick" or "McCormick Deering", and industrial tractors were "International". From the mid 50's on, Standard and utility tractors were "International" rather than "McCormick". Row crop tractors retained the "Farmall" designation through the 66 series of tractors after which all tractors were simply "International". Harold H
Nebraska Cowman
09-03-2004 03:29:04
Farmall is the name used to designate the row-crop version of International Harvester tractors. McCormick was an old trusted name left over from the early farm equipment days and was dropped in the 60sor early 70s. You are correct to use the Farmall name.
Tommy
09-02-2004 23:10:26
CASE Farmall International Harvestor (subject to change anytime)
Harold H
09-03-2004 08:27:10
 Re: WHat the heck do you call it? McCormick? IH? F in reply to Tommy, 09-02-2004 23:10:26
Case had nothing to do with International Harvester at the time of the Farmall 300.
Harold H
