tractor sputtering under load
farmall 340
09-03-2004 18:20:39
My tractor is backfiring and shooting flames out the exhaust any time I put it under a load. such as starting in a high gear, going uphill, trying to plow It seems to run fine up until you put a load on it. I am looking for any help you can offer. I did clean the sediment bowl out and drained the carb bowl a couple times to try getting any crap out
lee
09-04-2004 12:41:50
 Re: tractor sputtering under load in reply to farmall 340, 09-03-2004 18:20:39
Check the plugs for carbon fouling and clean or replace. Do the ignition work first, clean and /or replace points, set timing. Your problem is most likely in fuel delivery or dirty carb but I always go thru an ignitiion tune-up first.
MagMan
09-03-2004 18:32:24
How about a tune up Check points clean or replace, Wires, Plugs and Gap, And then maybe Valves, Also Re adjust the Carb settings first.
JON
riverbend
09-03-2004 18:32:04
Try cleaning the points.
