H farmall modification
Walt in Mo.
09-04-2004 14:39:34
looking for info on switching rearend around to use H like a forklift set up have heard there is away to switch pinion and rearend to have 5 reverse and one forward?? any ideas
Harold H
09-05-2004 03:36:52
 Re: H farmall modification in reply to Walt in Mo., 09-04-2004 14:39:34
You have to get a reversable transmission top which has the reversed shifter forks. You remove your old top, flip the differential, and install the new top with the reversed shifter rails. Check some of the southern salvage yards. You want a reverse top that was used on low drum cotton pickers. Should not be too hard to find. When you make the conversion, if your tractor is a tricycle, also be sure and turn the steering bolster around to reverse the caster so it will steer right.
Harold H
RayP(MI)
09-04-2004 17:29:05
Used to work at a pickle factory where we had several Farmalls revised this way, to make forklifts. 'Course, seat and controls had to be reversed too, but they worked.
Nebraska Cowman
09-04-2004 16:34:29
not hard at all. just put the carrier in upside down. you can do it in your sleep, hahaha, it's been done before, don't laugh.
