H block studs
Dale L
09-04-2004 15:42:54
I removed the head studs out of the block on my H so I could plane the block. Now that I'm ready to put the studs back in I noticed Five studs are longer than the others. Does anyone know where the long studs belong? thanks.
Wayne Swenson
09-04-2004 19:18:07
 Re: H block studs in reply to Dale L, 09-04-2004 15:42:54
My son & I just finished an "H" engine rebuild. We took all the bolts out to more easily remove the sleeves. The long bolts are located as follows: in the center of the head are 3 bolt holes with a circular pattern around the them. They are nearly under the rocker arms. These 3 are where the 3 thick washers go so the bolts need to be a bit longer. On the left side of the head the throttle pivot bracket is located; it needs 2 longer bolts also. CAUTION #1: Be sure to put a sealant on the threads when installing if the bolt hole protrudes into the cooling passage. (poke a wire into the hole to see if it it bottoms out or goes on into the cooling passage. CAUTION #2: measure the thickness of the head plus gasket thickness and only thread the bolts in far enough so the nuts can have full thread engagement. We had to back some bolts outa little when the nut only had 3/4 of the thread used. Experience, you know!!
Dale L
09-05-2004 08:31:06
 Re: H block studs in reply to Wayne Swenson, 09-04-2004 19:18:07
Thanks for the info I don't know how I'd get by restoring my tractor with out this web site.
MagMan
09-04-2004 16:44:57
I would guess Where the throttle linkage hooks up would be two and maybe the center of the head. I think there is a different set of washers there so maybe you need longer ones Just a guess Though. I removed mine the other day and never really looked or gave it a thought. JON
