changing points on an H distributor
Charlie M
09-04-2004 17:30:37
My H was running kind of crappy lately so I decided to change the points and condenser - fixed her right up. My question is does anyone have any tips for putting those tiny screws back in. I curse them everytime I change the points and condenser. Also does anyone know the size of the nut that holds the condser wire and points to the side of the distributor? Mine seems to be an odd ball size.
fix it
09-05-2004 16:06:50
 Re: changing points on an H distributor in reply to Charlie M, 09-04-2004 17:30:37
end the points problem, put a electronic ign in it and end the points problem
Nebraska Cowman
09-05-2004 04:08:32
even when I was a kid and could still see I always took the distributer or mag off to work on it. Why fight it?
MN Scott
09-04-2004 20:06:07
I use a magnetic screwdriver, the type with the interchageable bits, works great. As for the wrench I use one that my uncle had modified with a file years ago. Replacing points seems to get harder every year, must need glasses or something.
Wayne Swenson
09-04-2004 19:20:43
You need a new tool, right??
Go to your local supplier or Sears catalog and order a slotted screw starter.
You can also get a phillips style as well.
With them you can put a screw in any positon without dropping.
Jim in michigan
09-04-2004 19:17:47
I have had good luck with a tiny bit of grease on a screwdriver, holds the screw on the end nicely,,Jim
Boyd
09-04-2004 18:30:52
Sorry CNKS, I meant Charlie, Boyd
riverbend
09-04-2004 18:30:04
Change them to socket head cap screws. They stick to an allen wrench pretty well. Use a ball driver to tighten them. It looks like the nuts (and all the screws) are 8-32. They did manage to use three different types of screws in there - fillister head, pan head, and round head.
CNKS
09-04-2004 17:49:01
For tight places I sometimes tape the screw to the screwdriver. There is no real easy way. Don't remember the wrench size, I just try until I find one, I think I have all the smaller sizes.
MagMan
09-05-2004 04:26:19
 Re: changing points on an H distributor in reply to CNKS, 09-04-2004 17:49:01
I think its 11/32 not completly sure I do the same just grab untill it fits. JON
