Cork plugs in Farmall H near oil pan???
John in Ct.
09-04-2004 19:42:06
I am doing the pan gasket in my Farmall H. I found 2 cork plugs (crumbling) on the block above where the oil pan bolts to. I was wondering, are those 2 cork plugs necessary or will the pan gasket make up for them? also, should I replace those 2 little felt plugs near the rear main? Thanks!!
John in Ct.
09-06-2004 19:25:31
 Re: Cork plugs in Farmall H near oil pan??? in reply to John in Ct., 09-04-2004 19:42:06
Thanks guys!!
John *.?-!.* cub owner
09-06-2004 10:45:15
John, it's been too long since I worked on an H to remember just where you are atalking about, but IH put cork plugs in practically all the unused bolt holes at the factory before painting to keep them clear.
red paint gotta pull
09-05-2004 16:01:03
I would replace all the cork plugs because on the M I have it seals from the block to the main bearing caps
