Tire Pressure - Farmall M Front Tires
I Should Know T
09-05-2004 07:59:15
This is a really basic question that I should know but can someone tell me the ideal tire pressure on my narrow front Farmall M. The most weight I hang off the fron is 600#. There is no indication of oressure on the tires.
Thanks.
The Red
09-05-2004 08:38:07
 Re: Tire Pressure - Farmall M Front Tires in reply to I Should Know This...., 09-05-2004 07:59:15
I pump them up to 30 pounds if the tires are in good shape.
I Shouls Know This...
09-05-2004 08:41:42
 Re: Tire Pressure - Farmall M Front Tires in reply to The Red, 09-05-2004 08:38:07
Thank you.
The Red
09-05-2004 10:04:26
 Re: Tire Pressure - Farmall M Front Tires in reply to I Shouls Know This..., 09-05-2004 08:41:42
My 2 year old Titans have this tiny print which reads not to exceed 35 psi while setting the beads, both on the fronts and the rear tires. No recommended pressure is posted.
