Overhaul B
Mr. Mayor
09-05-2004 09:33:57
Overhauled my B engine. New everything. It starts and runs like a top. When starting I get one big puff of oil burning colored smoke and then it's clear as a bell. Is this because the rings are not seated yet? It has only run about two hours total.
Sandy
09-08-2004 20:34:04
 Re: Overhaul B in reply to Mr. Mayor, 09-05-2004 09:33:57
Hi, I just got a B and she's stuck. I don't know how badly yet. She was just delivered today, so I'll probably check her out tomorrow. Would you have any info you would like to share about overhauling the B? Things to do, check for, replace, etc? This is my first mechanical restore. I usually just do the sheet metal. Thanks in advance.
Loren
09-05-2004 09:39:01
Usually a single puff is oil getting by the intake valve guides. Sits on top of a closed valve and then gets sucked in and burned on startup. Puff.
Mr. Mayor
09-06-2004 05:33:15
 Re: Overhaul B in reply to Loren, 09-05-2004 09:39:01
Why would this be with new valves and guides??? I would think that the valve to guide clearance is as good as it's gonna get.
