Order Farmall Cub Parts Online
Cub Cadet Original carb float sticks
Grant MD
09-06-2004 12:29:10
The float in the carb on my cub original keeps sticking, and i was wondering if anyone had any ideas on how to fix that. It'll only run for about a minute before gasoline floods the air filter. I've replaced all the gaskets in the carb and tried adjusting the float but i still get the same result. Any ideas?
Dale L
09-06-2004 13:04:10
 Re: Cub Cadet Original carb float sticks in reply to Grant MD, 09-06-2004 12:29:10
I had a simalar problem with the cub cadet the kids use. the mower would run for a minute then kill. The problem was the needle would stick to the seat of the inlet valve. I got a carb rebuild kit and the new needle valve had a little wire that pulled the valve of the seat when the float went low in the bowl. Make sure you have that litte wire on your neddle valve.The orginal valve didn't have one. I hope that makes sense. LOL.
