Tractor wieght of a SA B
Greg-N-CA
09-07-2004 07:20:30
I'm looking into purchasing a "Gear Box" trailer for going to shows. I need to find out the weight of these 2 tractors, a Super A and a B. Does anyone know these specs without wheel weights?
Dennis in OR
09-08-2004 08:43:13
 Re: Tractor wieght of a SA B in reply to Greg-N-CA, 09-07-2004 07:20:30
i did not know the first time i got one DO THE BEST YOU CAN HERE FOR RIDE AND SAFTY ALSO LOOK AT TIRE SIZE, BRAKES ,RAMPS. IS THE B a tri ect .goose, dove, tie downs. my next one will be built to order.
Hugh MacKay
09-07-2004 17:16:33
Greg: My SA with no chloride or wheel weights is 2350 lbs., seat empty. Pretty much a factory tractor.
Red Dave
09-07-2004 07:45:07
My B weighed in at 2140 lbs. No water in tires, no wheel weights. Pressed dish wheels, not the cast ones, half tank of gas and nobody in the seat. It has a starter & a battery.
I never weighed a Super A, but I would expect it to be slightly heavier due to the heavier front end, cast wheel on the right side and the hydraulics.
Greg-N-CA
09-07-2004 07:56:58
 Re: Tractor wieght of a SA B in reply to Red Dave, 09-07-2004 07:45:07
Thanks Red Dave, this will give me something to work with this morning. We're going shopping for a trailer in a few hours.
