Farmall H with power steering
Barnstormer
09-08-2004 07:46:45
I'm normally on the Ford N's board but also have a Farmall H. My H has an after market power steering unit that a previous owner installed. To get it under the hood, they hammered a clearence into the hood. I'm restoring the tractor back to original (I hope).
While at a swap meet, I found a steering shaft to replace the one that has the power unit.
Has anyone else seen this application or have one installed on their H?
scruffy
09-08-2004 19:36:56
 Re: Farmall H with power steering in reply to Barnstormer, 09-08-2004 07:46:45
The power steering units are always hot on e-bay. The guys usually get between $250-$400.
Geoff NY
09-08-2004 13:46:33
Do you mean clearence for the unit mounted on the shaft or clearence for the pump? Usually guys massacre the hood putting the pumps on, but the shaft end should fit. Power steerin is a great feature.
